Rotary cutter slip clutch maintenance
   / Rotary cutter slip clutch maintenance #1
bsvitale
Vermont
John Deere 5045E
Have a new Frontier RC2072 rotary cutter. Used it once late last fall after I bought it, then covered it with a tarp and set it on some low blocking outside for the winter. Tried to leave enough space for airflow, but wish I had a better storage option.
Anyway, looking for advice on what maintenance I should do on the slip clutch this spring before use. The manual has a section on disassembling and inspecting. There's also this guy who says to "slip it": Slipping a Slip Clutch - YouTube
Should I at least inspect, even with this being a new unit?
   / Rotary cutter slip clutch maintenance #2
Yes! Not only inspect it but you should always "Slip It" also. Nothing worse than ruining your gearbox and/or PTO.
   / Rotary cutter slip clutch maintenance #3
What Mike said. A bit of a pain to loosen/slip/tighten, but something that's needed to be sure your clutch isn't stuck and risking damaging your PTO.
2019 Freightliner M2 106 Landscape Dump Truck (A50323)
2019 Freightliner...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
Miles read : 112,969 (A50323)
Miles read ...
Power River Livestock Chute (A50515)
Power River...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
