Rotary cutter stumpjumper nut??
   / Rotary cutter stumpjumper nut?? #1
countrybumpkin
Elite Member
Kioti, kubota
Need to replace the 1"-14 stump-jumper nut on my old fmc cutter, I have a new standard grade castle nut from a local hardware store but not sure if the nut should be a harden nut ? All the ones on line for rotary cutters are at least 15 dollars and black with a flange are these hardened ??
   / Rotary cutter stumpjumper nut?? #2
For that application you could hardly go wrong using a hardened nut- BUT, I'd check with a current manufacturer and see what they use: Woods, etc.
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
2015 INTERNATIONAL MA025 24FT REEFER BOX (A45677)
2015 INTERNATIONAL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
2017 INTERNATIONAL LF687 (A45046)
2017 INTERNATIONAL...
2011 Ford Ranger 4x4 Ext. Cab Pickup Truck (A46684)
2011 Ford Ranger...
2018 Wacker Neuson WL 38 (A48561)
2018 Wacker Neuson...
