Rotary Cutter Rotary Cutter
   / Rotary Cutter #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have an overgrown field edge I want to hog some paths into. Mostly woody brush up to 1 inch or so diameter, up to 2 feet tall. I was thinking of backing into the stuff from the open field with the RC lifted a foot or so, tail wheel off the ground. Then going forward over the same path with cutter lowered to 8 inches or so. That would allow me to check better for rocks and stumps after cutting with higher setting before lowering deck. Any thoughts??
   / Rotary Cutter #2
I cut that stuff all the time. Going backward is a PITA!~ I just lower the FEL to about 2-3" off the deck and go forward. Keep your hand on the 3pt lift lever and give a yank when it smacks something. No big deal, that's what they are made for.
jb
   / Rotary Cutter #3
Ditto what JB said.. I hate mowing with my mower up... lets all kinds of debri fly.
While I have backed into some areas and mowed backwards.. I usually just choose a slow gear and go forward and le tthe tractor front axle lay it all over.. Keep an eye out.. if you see a rock, stump.. car tire.. get onthe clutch and the lift.. etc..
soundguy
   / Rotary Cutter #4
Same advise as these guys gave you. Be more concerned about your tractor tires getting trashed. The cutter can hit all manner of things and keep on going.
   / Rotary Cutter #5
*Any thoughts??
*YEAH !
Sounds dangerous.
Hard tellin what that thing might throw into you and tear you up with it.
L . B .
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
2020 Caterpillar...
2021 New Holland Workmaster 25S Compact Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 New Holland...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
John Deere 6115D (A50120)
John Deere 6115D...
2001 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A50323)
2001 Ford Ranger...
