Rotary Mowers Bush Hog Vs Kingkutter
   / Rotary Mowers Bush Hog Vs Kingkutter
I follow what your saying, but if you look at the picture on the KK website there are 2 bolts at the top of the supports. One is where the U plate pivots on and maybe 1 inch below that pivot is another bolt that goes through the right lift arm into a spacer and then out the left lift arm. The spacer is sandwiched between the right and left lift arms just below the bolt that the U plate swings on . If that U plate was pointing at the tractor seat as it continues to rotate toward the ground it will hit this spacer that is 1-2 inches below the pivot point. Maybe I need to move that U plate to the lower of the 2 bolts so that it swings fore and aft and the Bolt with the spacer would be above the swinging action.... What do you think ?
   / Rotary Mowers Bush Hog Vs Kingkutter #22
Uh-oh, I apologize, Jason. It just dawned on me that it was my Bush Hog finish mower, not my Howse rotary cutter, that had the U-shaped connector that worked as I've been describing. And now after looking at that picture of the KingKutter rotary cutter again, I see what you mean, and right now I don't know the solution, except . . .
<font color=blue>Maybe I need to move that U plate to the lower of the 2 bolts so that it swings fore and aft and the Bolt with the spacer would be above the swinging action.... What do you think ?</font color=blue>
That's not the way the picture shows it, is it? But that sure seems to me to be the solution; only one I can think of anyway.
Giyi 78" Grapple (A53316)
Giyi 78" Grapple...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
(20) Pack of New HD Black Bungee Tie Down Straps (A54865)
(20) Pack of New...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2003 Big Tex 10PI...
Peacock Statue (A53316)
Peacock Statue...
