Rotor button question.
/ Rotor button question. #2
very close, spark jumps.
that's the design anyway... occasionally you see ill fitting parts yeilding broke rotors, or caps with grooved contacts and a pile of brass dust coating everything. this is usually preceded by a wobbling cap as it is running..
/ Rotor button question. #3
The button is in the cap, the rotor does touch the button, but it doesn't touch the distributor terminals. That's why they are replaced occasionally, the arching causes wear and a higher resistance as they do wear, just like spar plugs. There is a built in resistance but too much causes arching in unwanted area.
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2019 JCB 457 (A60462)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Asphalt Melter (A61572)
Asphalt Melter...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
