Rototiller questions...
   / Rototiller questions... #1
e.myers
Springhill, SC
Kubota L4400 4WD Hydrostat
What happens when a rototiller meets a pine stump?
Have 7 or so acres of land that has been cleared of pine stumps but there may be a few left.... not many however.
Property also has roots and a minimal amoutpartially decayed pieces of limbs between 2 & 3 inches diameter max and probably a foot long max (basically what the excavator missed/ couldn't grab because too small)
Wondering if I'd be a complete idiot to try and rototill the land before I do something else in an effort to find the stumps.
What would you recommend?
Also trying to eliminate buying/ the need for a chisel plow because my hp budget won't allow it. Is a chisel plow going to do anything for me that a rotary tiller would not do? I'm thinking the chisel plow is going to get deeper but not as deep as a subsoiler. How deep can I expect to till with a tiller.
Any brand recommendations?
   / Rototiller questions... #2
Make sure the clutch is adjusted properly on the tiller then hold on tight Buckeroo!
So, if the clutch is adjusted properly, I shouldn't tear it up?
Sounds like it'll be kind of like when my troy built garden tiller takes me for a ride when it catches a decent size root!
Will the tiller even ride over a stump that's protruding from the ground (no "guard" at ground level in the front?) I guess not because then you'd just kind of rip the tiller off the back of the tractor.
Would it make a difference if I had a forward or reverse rotation type tiller? BTW, why would I want one over the other?
   / Rototiller questions... #4
I would be a little aprehensive about using a tiller until I checked pretty thoroughly for stumps. The slip clutch set loose will certainly help, but you could do some major damage to your tiller and tractor if you're not careful. What about getting something like a 3 point rake (hp friendly as compared to deep ground engagement implements) to clean up the miscellaneous sticks, etc., and if there is a stump, you would feel it with the rake.
Are the stumps cut at the surface, below, or slightly above. If they are visible, walk your acreage and flag anything you want to avoid.
I have a forward rotating tiller, but have read where a reverse tine tiller takes more power to operate than the forward rotating, and is more likely to "hang" on an object, like a stump, than a forward rotating, that is more likely to go over the object. If you decide to till before doing anything else, I would set the slip clutch loose like bigdad recommends, and set your tilling depth shallow.
Let us know what you decide and how it works, we all love to hear the follow-ups.
   / Rototiller questions... #5
I'd try to find an old [ CHEEP] disc harrow befor taking a chance on tearing up something expensive
Alright.
Y'all have convinced me that I don't want to take a new tiller out there. Sure as the sun shines I'd miss a stump and trash it and be kicking myself later.
I actually have a very old disc harrow (a 4" diameter tree has grown up through it) that will probably do for at least finding the stumps. Have no idea as to the condition or what matters as to condition. Guess that is another thread.
Still need to look into the whole reverse vs forward tilling types. Some have both options I believe. Wonder what the theory is on both operations?
   / Rototiller questions... #7
Alright.
Today in between posting about your tractor purchase I have been rototilling a new patch of ground. I mentioned and recommended the 673 tiller with forward tine rotation because of the issues you are asking about here. With a forward tine tiller it will climb over the stump or chew it up if it is small. I live in the mountains in New Mexico and when working in poor ground can routinely till through rocks the size of a 1 gallon container and smaller. Occasionally a small rock or limb will jam and stop the tiller but not often. As mentioned while tilling today I flipped up may large rocks and roots without damage to the tiller.
I use a landscape rake to clear as much debris as possible but still you are going to find stuff in new ground. These tillers are really tough.
steve
   / Rototiller questions... #8
2cents
i would certainly go over the place with my bladebox teeth at max depth before going in with the tiller. (dont know how good discs are in pulling up stumps)
Had my 3pt toplink broken due to a rock at the moment of lowering the tiller into the ground. thumb smashed but that was my mistake.
One difference between the forward-backwards tillers is when something breaks on a forward tiller (as mine) it will try to overtake the tractor, most of the time this means jumping up and pivoting towards the back of tractor.
Preparing the land with discs or ripper teeth will make it an easier and faster job for your tiller anyway, so why risk anything.
   / Rototiller questions... #9
When I get into a root or a rock I can tell because the tiller will jump and you can hear it hit the inside of the tiller box. BANG! As much stuff you can expose in your path the better.
   / Rototiller questions... #10
mr myers, i sent you a private message that should be of some benefit.
2016 Quincy QSI-370i Rotary Screw Air Compressor (A46683)
2016 Quincy...
2025 Swict 78in Bucket Skid Steer Attachment (A46683)
2025 Swict 78in...
84in. Skid Steer Snow or Litter Bucket (A46502)
84in. Skid Steer...
2019 Mercedes-Benz Sprinter 1500 Van (A46683)
2019 Mercedes-Benz...
Cub Cadet Ultima ZT1 (A47307)
Cub Cadet Ultima...
2018 John Deere 4044R MFWD Tractor (A46502)
2018 John Deere...
