Rough running engine
   / Rough running engine #1
dsolsbery
I have a Hinomoto E 222 with a 3 cylinder diesel engine. For a while now it's been running rough like the engine is flooding, and seems to smoke quite a bit. I've heard that the fuel injector pump can be timed, and if it's out of timing, would it cause the problem I'm having? If anyone one has done this before, would you mind filling me in on how to do it?
Is there anything else that can cause these symptoms?
Thanks in advance,
Dennis
   / Rough running engine #2
The injector pump can't get out of time unless it is removed. You could have low compression or coolant mixing with fuel either of which can be caused by a bad head gasket or cracked head.
Eugene
   / Rough running engine #3
Have you changed air or fuel filters lately? I'd make sure they are clean.
Pit Boss Lexington Wood Pellet Grill Smoker (A49462)
Pit Boss Lexington...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
LandHonor 15,000lbs Hydraulic Logging Winch Skid Steer Attachment (A49462)
LandHonor...
