Panik
Platinum Member
- Joined
- Mar 29, 2013
- Messages
- 508
- Tractor
- Kubota bx2360
Has anyone had much luck trying to get Roundup/generic glyphosphate to re-dissolve after it has sat and started to form a slimy white film?
I went to use my 15ga sprayer for the first time this spring and after an hour or so use I noticed the pressure and output had decreased. Figured that because I was running a longer than recommended hose for the 1ga./minute pump that I had probably exceeded its abilities. Went to TSC this morning to pick up the next size larger bypass pump and in the process of getting it installed noticed that the tank strainer basket was clogged with white gunk.
After doing a bit of reading realized I had had a "Duh" moment and probably should have checked the strainer first prior to running out and getting a new pump. I also should have dumped the tank after last season..... I'm still somewhere low on th learning curve. Anyways it was a excuse to upgrade pumps because I hadn't really liked the on demand pump that had come with the tank.
Anyways, I do realize that the common recommendation is to mix fresh each time. I was just wondering if anyone had tried rigging a recirculating/mixing line on their spray setup and if doing so might help to re-suspend Roundup mix that had been sitting for a while?
