Rtv Fuel Filter when Too Replace????
   / Rtv Fuel Filter when Too Replace???? #1
inseeme
Stoneville, NC
Kubota M7040
I have 117 hours on my Rtv when should I replace the fuel filter, runs fine no problems. knock on wood!!!!
   / Rtv Fuel Filter when Too Replace???? #2
If it ain't broke then don't fix it.
   / Rtv Fuel Filter when Too Replace???? #3
And then it's to late.
Best advice is to change it at the maintenance interval listed in your owners manual. It's alway's better to change it early to prevent problems than to wait until it doesn't work and have to troubleshoot the problem and fix it.
   / Rtv Fuel Filter when Too Replace???? #4
I have an JD HPX Diesel. I change the oil(2qts), oil and fuel filter every 50 hrs. Also change the air filter (inner and outer) every 100 hrs. The fuel filter is too cheap and important not to change it with every oil change. I think Kubota's fuel filter is about the same as what JD uses.
   / Rtv Fuel Filter when Too Replace???? #5
I change my fuel filter every 500 hours or once a year, which ever comes first. This is the JD recommendation.
You did just remind me that I'm way past due on the BX2230.:eek:
   / Rtv Fuel Filter when Too Replace???? #6
The Kubota RTV900 service manual says to check condition of fuel lines and filter every year but if no problems are found that you'll only need to change the fuel filter every 500 hours.
The generic service schedule on the Kubota website - this covers all their equipment - says to change the fuel filter every 300 hours.
   / Rtv Fuel Filter when Too Replace???? #7
When it's running, no fuel will stand in a clean filter~!
Thanks for all the help I will probably get it at the 150 to 200 hour mark! thanks again.
IH 686 Tractor (A50514)
IH 686 Tractor...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
City of Tampa (1709) VIN: 1FTYR10U67PA38092,**Title MUST be transferred into buyer's name INCLUDING (A51692)
City of Tampa...
