rust control - POLY-FIBER TUBE SEAL LINE OIL versus Fluid Film
   / rust control - POLY-FIBER TUBE SEAL LINE OIL versus Fluid Film #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Has anyone here used POLY-FIBER TUBE SEAL LINE OIL ?
Reads like fluid film on steroids:
Prevents rust and corrosion inside aircraft tubing structures. Tubeseal is a blend containing a very fine preservative oil (MIL-L-21260) which has a characteristic of climbing the tube wall and spreading over the entire surface to provide lasting protection. Penetrates and reveals very small pin holes in a weld and in time, due to exposure, congeal and seal the hole. 1 quart will treat 2 light aircraft fuselages.
   / rust control - POLY-FIBER TUBE SEAL LINE OIL versus Fluid Film #2
Never heard of it, but it sure sounds good.
   / rust control - POLY-FIBER TUBE SEAL LINE OIL versus Fluid Film #3
Poly-Fiber
Raw Linseed Oil, EC# 232-278-6, CAS# 8001-26-1, Content: 25-55%
Fluid Film (gal)
Refined petroleum oil, hydrotreated heavy paraffinic, CAS# 64742-54-7, Content: 50-90%
Calcium petroleum sulfonate, CAS# 61789-86-4, Content: 1-10%
JOHN DEERE 158 FRT IDR ATTACHMENT (A51247)
JOHN DEERE 158 FRT...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
PALLET OF 25" X 33" STAINLESS STEEL SINKS (A51248)
PALLET OF 25" X...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
