Rusted bolts
   / Rusted bolts #11
Did they happen to mention which type of ATF? Acetone is nasty stuff around plastic and paint finishes but good for removing nail polish....,. I've also heard that a few oz of it in a tank of gas reduces the surface tension of the fuel and promotes a LOT better fuel mileage. I guess its possible that it does the same thing with the atf allowing better penetration....
Be careful adding Acetone to fuel. I worked at a Chem Hauler w/ 6 owned tractors and a dozen owner operators. All of a sudden the Lease Operators stopped using the fuel pump and within a week we had two company tractors down w/ holes melted thru pistons.
I found out later that a Lease Operator who was POed at the boss dropped an Acetone 'heel' down into the fuel tank and warned everyone to stop fueling at the terminal 'cept the company drivers.
You can increase octane adding either Xylene or Toluene to gas; that's what is in most octane boosters...
   / Rusted bolts #12
Well, the metal oil can lasted a day before the seal on the spout went and left oil on my work bench.
   / Rusted bolts #13
look for this designation on the bottom of containers...if it has this mark it will safely hold acetone
120px-
High-density polyethylene (HDPE)
   / Rusted bolts #14
I thought acetone was bad if your breathe the vapors and can be absorbed through the skin. I don't doubt that you could homebrew a good working penetrating solution with it, but I'm not so sure I want to use it everyday. :eek:
I don't think the price of Kroil oil is that bad when you buy it on sale compared to actually being able to get things that are stuck loose.
   / Rusted bolts #15
I'd like to have seen results for straight ATF as its been used as penetrant for years.
   / Rusted bolts #16
acetone is great for cauterizing cuts and scratches...it hurts like heck for a second but in a pinch it works a lot better than the "cowboy Way" (smearing gun powder and ignighting it)...
Caution is paramount when using any keytones...be sure to keep a tight lid on acetone cans or the next time you need some the can may be dry...
Also if there is a fiberglass supply store in your area you may find it much cheaper than a quart from Home depot etc...
   / Rusted bolts #17
The thing i like about Kroil, compared to all the other penetrants ive used, is that it will wick itself into the threads of seized things. You can actually watch it climb up the threads!!! THats its secret i think.
Most of the other things ive tried, have been more viscous than Kroil, and i think thats why they dont work as well.
I wonder if the ATF/Acetone mix will have those same properties? I imagine it will be thin enough?
   / Rusted bolts #18
it is the lack of "surface tension" in acetone (as previously mentioned by another member) that gives it that ability
FWIW...adding a drop of liquid soap to water greatly reduces the surface tension...i.e., you can make a (double edge) razor blade float in hard water due to surface tension...add a drop of soap and forget it...
This is the same reason soap is often added to oil sprays for fruit trees (it make it stick to the leaves)
   / Rusted bolts #19
1. Heat rusted bolt/adjacent area with torch
2. Pour cold water on rusted bolt/adjacent area
3. Loosen rusted bolt
4. Hopefully nothing cracked, but it works!
2003 Sailfish 188 18ft. Boat with S/A 20ft Boat Trailer (A55853)
2003 Sailfish 188...
2022 Bogballe M45W (A53317)
2022 Bogballe M45W...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2019 John Deere 8295R MFWD Tractor (A53485)
2019 John Deere...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
