rx7320 Air conditioning problems
   / rx7320 Air conditioning problems #1
jonu1428
Powell, Ohio
Kioti ck30 HST
Has anyone had issues with air conditioning ? I have Rx7320, Replaced entire unit in roof and compressor and still barely working.
   / rx7320 Air conditioning problems #3
AC is a complex business especially when replacing major components, you need at least a set of gages as well as a vacuum pump to pull the system down and boil out all the moisture, you also need refrigerant as well as the correct amount of PAG oil and the correct type as it depends on the system you have. I do my own ac recharges and have for a while now. I've never had to replace any components other than a refrigerant dryer once and my tractors are from the late 70's. and will freeze your butt out on the hottest days. The y all leak down after a while, fact of life. I do the cars and trucks as well.
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2016 INTERNATIONAL...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45333)
WICHITA TANK...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
2016 GMC 2500 HD Z71 (A44501)
2016 GMC 2500 HD...
2012 INTERNATIONAL 8600 TANDEM AXLE DAY CAB (A43004)
2012 INTERNATIONAL...
377483 (A44391)
377483 (A44391)
