RZT 50 PTO disengaging in reverse
   / RZT 50 PTO disengaging in reverse #1
kevinhuth
This may be the wrong place to ask this, if it is could anyone tell me who to ask. i have a cub cadet RZT 50 the PTO disengages when i go in reverse. can i modify it so it will cut grass in reverse. thanks
   / RZT 50 PTO disengaging in reverse #2
Usually there is a switch under the mower that is activated by the reverse pedal. Find the switch and bend or move the switch operating lever so the pedal does not depress it.
Bob B.
   / RZT 50 PTO disengaging in reverse #3
Yes, it has been posted here.
Do a search. RZT 50
   / RZT 50 PTO disengaging in reverse #4
The zero turn mowers have two reverse switches one for each steering lever both of which have to be engaged for the the pto to shut down. You only need to disable one. acording to the wiring diagram for my Z50 they are normally closed switches so all you should have to do is put a jumper wire across the connections on one.
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
