s370 injeter pump
   / s370 injeter pump #1
cajun c
opelousas,la
satoh beaver s370
can any one tell me how to pull the pump on this little guy
other than just pulling it off dose it need to be at a timing setting like TDC ???
   / s370 injeter pump #2
It just pulls off. Timing is set with shims under the pump. Be careful when reinstalling the linkage to the pump that it goes back into the same position as when you removed it otherwise it could cause rack setting issues (too much or no fuel). I've pulled these pumps a number of times and never had problems with the linkage going back together but it's something worth paying attention to.
2017 KOMATSU D39PX-24 CRAWLER DOZER (A52705)
2017 KOMATSU...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A55787)
2022 Caterpillar...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
(APPROX 7) 8" I BEAMS UP TO 10' (A54756)
(APPROX 7) 8" I...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
