SA424 Will not move forward or reverse.
   / SA424 Will not move forward or reverse. #1
JJRODD
2014 Yanmar SA424
2014 SA424, exited the tractor with the engine running I didn't set parking brake. The tractor shut down as expected. Once I started the tractor it will not go forward or reverse. Front loader and 3 point works fine. Hydraulic fluid is in the center of the sight window. Any ideas?
   / SA424 Will not move forward or reverse. #2
Winston said. (y)
   / SA424 Will not move forward or reverse. #3
When you push on the pedal do you hear the hydro trying to move the tractor? Are you certain that the brake is disengaged. Mine has stuck before, a couple times, and it would not go anywhere. Have to push down on it a little harder to get it disengaged.
   / SA424 Will not move forward or reverse. #4
If all the linkage is working and moving properly. Hyd. Trans. etc..
  • Cast iron transmission and front axle and dual hydraulic pump
  • Two side-by-side hydrostatic transmission pedals Full-frame chassis
   / SA424 Will not move forward or reverse. #5
JJRodd, Have you repaired the tractor
2013 Hackney Beverage Trailer (A46443)
2013 Hackney...
Hedge Posts (A46502)
CAT Bucket W/ CAT Coupler (A43476)
CAT Bucket W/ CAT...
2015 Ford F-750 Terex Hi-Ranger 5TC-55 55ft Insulated Bucket Truck (A46683)
2015 Ford F-750...
2011 Ford F-150 Pickup Truck (A46684)
2011 Ford F-150...
Outdoor Ice Merchandiser (A45336)
Outdoor Ice...
