Safely shifting a nut on a differential bevel pinion
   / Safely shifting a nut on a differential bevel pinion #1
dennis52
Queensland Australia
Kioti DS4510HS , Kubota B7100
On my Kubota B7100 there is a 1 and 1/4" nut sitting on the splined drive shaft in front of the 4WD differential oil seal I want to replace.
The torque setting for the nut is listed at about 85ft/lb.
When I begin to turn the nut with my shifting wrench the force is being transmitted through the diff and outer drive axles to the tyres on the floor. There is the desired resistance on the shaft rotation , but it feels like things might be bending and that I might damage the diff if I continue.
Can I safely transmit this much force through the diff so as to get the nut off the bevel pinion shaft then tightened again.Am I being over cautious ?
At a pinch, to remove the nut , I could put a pipe wrench on the splined shaft and against my floor to stop the shaft rotating. Problem is when I come to put the nut back on I'll need a different technique as I'll have to get the right torque setting and use a torque wrench with a socket that encloses the whole splined shaft .
Anyone removed this nut? The seal looks easy.
   / Safely shifting a nut on a differential bevel pinion #2
Are you certain it is ft/lbs, and not in/lbs? The only pinion nut that I have changed was on a Ford Bronco II, and the pinion nut torque was measured in in/lbs.
   / Safely shifting a nut on a differential bevel pinion #3
Crank it off. The 1 1/4 nut and shaft should be robust enough to handle most anything you can throw at it. You might have to use an inpact wrench.
Thank you.
I guess I was more concerned about the robustness of the spider gear and bevel ring gear inside the diff to take the force of holding the shaft as I shifted the nut.I haven't worked much on diffs.
Still feel it would be OK ?
Definitely ft/lbs.This nut sits outside the diff housing.
   / Safely shifting a nut on a differential bevel pinion #6
The inch lb number usually refers to the amount of torque required to rotate the assembly after the crush sleeve is tightened to the ft lb required. It verifies that you have "crushed" the sleeve sufficiently to provide the proper amount of pre load on the pinion bearings.
   / Safely shifting a nut on a differential bevel pinion #7
I'm no expert, but most ring and pinion assemblies, at least in larger vehicles and tractors, are designed to take a huge amount of stress. If in serious doubt, consult a Kubota mechanic.
Thanks again TC. What you say makes sense. I'll get on with it now
   / Safely shifting a nut on a differential bevel pinion #9
Correct, I had forgotten that was why I had to buy a torque wrench that measured in low-numbered inch pounds.
That was one of those "you want how much to install a $10 seal? Thanks, I'll just install it myself." Two days later and a new torque wrench, I had the pinion seal installed.
   / Safely shifting a nut on a differential bevel pinion #10
impact gun takes it off.. easier...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
DEUTZ MARATHON...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
iDrive TDS-2010H...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
