Same Rubin 150
   / Same Rubin 150 #1
Chris Chris
Same Rubin
hello guys, I have a same rubin 150, when I close the PTO with the off button it doesn't stop. is normal ; how can i stop it ;
   / Same Rubin 150 #2
If you don't get an answer here try asking in this thread: All Other Brands
   / Same Rubin 150 #3
Does it ever stop? Sounds like a hydraulic “wet clutch” PTO and either the solenoid valve that the switch controls is stuck or not hooked up.
Also, the PTO brake is worn, the brake actuator is bad or the hydraulic system for the PTO is leaking by internally, but this usually causes the PTO clutch to slip under heavy load.
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
JOHN DEERE 2350 TRACTOR (A54756)
JOHN DEERE 2350...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
