Sand paper, what type to use on slip clutch hub.
   / Sand paper, what type to use on slip clutch hub. #1
Newtogreen
Bronze Member
Harpers Ferry,West Virginia
JD 4115
I am trying to smooth out both side of a rusted hub that came out of a slip clutch. I have cleaned the rust off but now need to smooth the hub out some so it won't be so hard on the friction disks. What type and grit of sand paper should I use. Thanks for any info. Larry
   / Sand paper, what type to use on slip clutch hub. #2
Might try some emery cloth of 60 or 100. Then when smooth, put some polish on it with some 400 or 600. Use a block of wood for backing so you take off the high spots, and don't deepen the low spots.
But you are going to more work than I would be. :) Good on ya.
   / Sand paper, what type to use on slip clutch hub. #3
I would not fool with it it will grab better rusty.
   / Sand paper, what type to use on slip clutch hub. #4
I'm onboard with the emery cloth idea, if thats not available then use the sand paper routine. The ides is for it to slip when needed, and rust prohibits that action. But you don't want it so slick that it will slip.Just like an auto clutch disc.
   / Sand paper, what type to use on slip clutch hub. #5
G'day i would not bother making it too shiny most clutches are adjustable don't tighten up too tight ( enough to drive and then a little more ) and leave it at that, the rust will burnish off when it slips
Jon
Thanks for the ideas, I don't want it to slick but I do not want it to grab, that would defeat its purpose. I need to know what would make easy work of it. Thanks Larry
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
Scaffolding (A52377)
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
Estate Equipment Auction 9/27/2025
Estate Equipment...
Test Button (A47477)
