Satoh Beaver tiller
/ Satoh Beaver tiller #1
z28clone
Ashville Ohio
370D
I have a problem that most Satoh owners wish they had. I have an S-370D Beaver with front end loader and backhoe. I just bought an S-373 Beaver with a tiller. Tiller is a 1110S model but what I didn't check before purchase was the PTO rotation. My S-370D PTO turns CCW, this newer Beaver turns CW. My plan was a use the tiller on my S-370D and sell the S-373. The S-373 is in alot better shape than my S-370D. Can I move my backhoe and loader to it? Problem still is the backhoe uses a PTO pump, which needs to turn CCW. I only want to keep one tractor. Any ideas appreciated.
one pic is pto from the S-373 and the other is from my S-370D with the coupler on it for the Backhoe pump. Do I have a PTO reverser on the S-373? Is it easy to remove and put on every time I want to use the tiller?
/ Satoh Beaver tiller #3
373 doesn't appear to use a reverser. Is your backhoe a Blackhawk? I'd think it easier to adapt the loader and hoe to the 373 than it will be to find a reverser for your 370 though I do recall seeing on one eBay recently.
Yes, backhoe is Blackhawk. How will using the loader if moved to the 373 effect not having 4WD?
/ Satoh Beaver tiller #6
373 isn't 4wd?
I didn't catch that. You can use a 2wd tractor with a loader but having rear weight is critical. Were I in your shoes, I'd sell the 373 and use the proceeds to buy that PTO reverser I linked to on ebay. You'll have a lot less work to deal with. Personally, i won't have a tractor without 4wd. Too many times it's been the difference between getting out of where I am or needing a pull.
/ Satoh Beaver tiller #7
You can get an excellent idea of what it the 373 will do with the loader and backhoe by merely running your 370 in 2wd. Try it out that way, and see how it works for you. For my purposes the small (Say, under 1500lbs bare) tractors need 4wd when equipped with a loader to be able to function properly in my conditions and usage. You may be able to do just fine with 2wd; I cannot.
You are able to just get a different hydraulic pump that matches your PTO rotation so that your backhoe would work.
The close-coupled tiller drive won't work with the reverser as-is; substantial (and depending on your abilities and tools, expensive) modifications will be required to space back the tiller mount and lift arrangement. This does not mean it would be impossible, but it wouldn't be a slip-on addition.
After staring at the tiller with a beer in hand. I came up with a possible answer. Since the tines are removable, all I need to do is remove them and turn them the opposite direction. Also the PTO shaft on the 373 is 6 spline, so I will need the adapter to fit on my 370. What you do guys think of this idea?
/ Satoh Beaver tiller #9
You'll be happier if it's turning properly. If you revers their direction you'll be moving the tilled ground where you don't want it.
Buy the reverser, sell 373 and done.
/ Satoh Beaver tiller #10
I believe there is a tensioner on the drive chain of the tiller that would be damaged if you ran it in a reversed direction.
The adapter is available for the PTO output.
/ Satoh Beaver tiller #11
I have a manual for the tiller used with the MT180 and MT160. (2PR-1110OS)
From all the diagrams there is no idler or tensioner so reversing the tines should actually work.
/ Satoh Beaver tiller #12
For what it is worth, I would keep the 4X4 tractor without a doubt.
/ Satoh Beaver tiller #13
This is good to know! What type of gear mechanism is in the 90 degree box that redirects the PTO shaft power to the drive gear? Is it plain bevel gears, or do they appear directional?
I appreciate all the help. I tried the tiller out with the 373 last weekend. Worked great even with 9 tines broken off. All I need to do is replace the 8 spline yoke on the end with one with 16 spline and it should work with the 370D. Making the tiller turn ccw will make the tiller rotation turn in reverse. Reverse turning tillers are better for chewing up hard ground and pulverizing soil.
Just to update everyone. I used this cw pto turning tiller on my ccw pto beaver all spring and summer. It works great, tho it gives you a pile of dirt at the end of each path. I just learn to slowly raise it before I get to the end of each row.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
KBH Water Trailer BNT-1 (A61306)
KBH Water Trailer...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
UNUSED 250 GALLON FUEL TANK (A60432)
UNUSED 250 GALLON...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
