Satoh Beaver transmission diagram
   / Satoh Beaver transmission diagram #1
RevSev
I am in need of a transmission diagram for my Beaver. When I purchased
the tractor it would not go into reverse. Opened up the transmission and
found the problem, however I noticed that the gear that controls the 4X4
appears to have been put in backwards. The guy that I purchased the tractor from had, had his son tear into it too try to figure out the reverse.
I have a feeling he didn't know what he was doing and ended up putting the gears back in wrong. I don't need a full service manual, I just need to make sure that the gear I'm concerned with is in properly. I searched the forum
back a couple of years hoping to find something on the transmission, but didn't find anything. Does anyone have a diagram or know of a site I can
go to?
   / Satoh Beaver transmission diagram #2
Welcome to the site.
You ask a very broad question, would help if you identified the tractor model number.
There are a couple of guys that monitor the site that could offer you manuals at decent prices.
Good luck in your 'repair'.
   / Satoh Beaver transmission diagram #3
I have been told that the 370 Beaver is completely different than the 372 and 373 Beaver. Which is yours?
May sound like a really stupid answer, but I don't know which "beaver" it is.
Where do I look to find out? Serial #?
   / Satoh Beaver transmission diagram #5
I'm stepping out on a limb but I don't think the serial number will help. If you have decals on the hood, one might tell you. Also there should be a metallic sticker on the side of the frame on the front under the sheet metal that may have the model number, serial number and horsepower. This will look like aluminum or chrome, slightly larger than a business card.
I found the label you refered too on the frame (covered in oil, didn't even
know it was there) The tractor is a 370 D 15hp.
   / Satoh Beaver transmission diagram #7
Now go to Valley Power and choose the parts link on the left. Scroll down and you will find a diagram for S370 Beaver transmission gears.
Oliver, Thank you SO much for the help. This is exatly what I was needing.
Sights like this one are only a success because of people like yourself who
so graciously give of their time and expertice. Thank you again.
   / Satoh Beaver transmission diagram #9
You are welcome. I have been helped here many times myself. Keep us posted on your progress.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Box Blade Pull-Behind Tractor Attachment (A51691)
Box Blade...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
