Satoh Beaver transmission problem
   / Satoh Beaver transmission problem #1
sixpockets
hollywood, maryland
satoh beaver
While pushing manure back, my Satoh Beaver tractor decided it no longer wanted to go in any gear. Does anyone know where I can find a diagram of the transmission or any helpful hints on what to check?
   / Satoh Beaver transmission problem #2
first.. describe in precise detial what it will or will not do.
does the shifter go intot he gates for the gears, but nothing happens?
does it grind and not go in.. does it go in and slip out?
does it stall the engine?
does the pto work with trans in neutral?
in gear?
Shifter will not go into any position, the shifter does not go into any gates, I hear a grinding sound when I let the clutch out. It does not stall the engine. Not sure if the PTO works, didn't try that.
Does that help?
   / Satoh Beaver transmission problem #4
check the pto operation.
so.. if you shift without clutch does it grind just the same ?
if so.. clutch may not be disengaging flywheel... or pilot bearing seized and not slipping .. soemthing..e tc..
weren't riding the clutch were ya? or had no freeplay maybee.. ground fingers down on TO bearing?
will check the PTO operation in the morning. Didn't try shifting w/o clutch engaged. will try.
Thanks for your assistance. Hopefully I will gather additional information in the morning and will continue troubleshooting.
Appreciate your assistance in this matter. I've got to pull it out of the manure pile.....not exactly where I want to work on it!!!
   / Satoh Beaver transmission problem #6
once we get more info, we can make better guesses.
many things it could be.
hubs rip out of clutches.. etc.
if pto works.. that adds one more diagnostic bit.,
thanks....talk to you again tomorrow when I have more info....
   / Satoh Beaver transmission problem #8
i'll be on lightly tomorrow.. got a full day.. but when I se ethe reply I'll post.. someone else may hop in to help as well.
   / Satoh Beaver transmission problem #9
Also, were you able to shift into gear with the engine off? If so, if you try to start the engine with the transmission in gear and the clutch pedal depressed does the tractor try to roll or stay in place?
Ken
   / Satoh Beaver transmission problem #10
Which Beaver is it? 370, 372 or 373?
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
