Satoh Block Heater
   / Satoh Block Heater #1
BeaverBFTD
Seattle, WA
Satoh S370D
Does Anyone have a part number/source for a block heater for a Satoh Beaver S370D?
   / Satoh Block Heater #4
The only problems I encountered are due to the heater itself failing. You'll need to remove the starter to reach it. And drain the coolant of course.
   / Satoh Block Heater #5
If the engine is the 3 cyl diesel (K3), on mine it is located behind the oil filter, but guess any frost plug location will do.
   / Satoh Block Heater #6
The 370D uses a 2cyl engine. I need to pull the starter on mine one of these days to reconnect the plug for said heater. Somehow it wasn't properly seated.
   / Satoh Block Heater #7
Do you have an update on how the installation went?
I have an s370d that I will be bringing to Minnesota this spring and am planning on adding a block heater. Any insight or tips on the installation are greatly appreciated!
I ran in to a bigger problem. Looks like I may need to rebuild the engine. Once that is done it may start just fine without the block heater.
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
TMA (A49461)
TMA (A49461)
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
