Satoh Rotavator Replacement tines. 2PR-1101S
   / Satoh Rotavator Replacement tines. 2PR-1101S #1
Baziscad
Satoh St1501
Hi Guys, I'm new here but did spot a question shown on the forum I believe back in 2014 regarding replacement times/blades for a Satoh Rotavator, mines a 2PR-1101S. Didn't appear to be any answer to that thread but just wondered if anyone had any information to date. I need to replace the tines but am unsure what exactly what they should look like as mine are basically worn to a straight blade with an evil point, they outside two do have a curve on them. These are fixed individually in a housing on the shaft by one single bolt, with a 10/12mm hole and approximately 22/25mm in width and approximately 220mm high. I know Satoh were taken over and produced by Mitsubishi at one point, but that's about all I can discover. Any help would be appreciated, as although it does cultivate to a degree, the straight tine do leave solid ridges between them in the ground.
   / Satoh Rotavator Replacement tines. 2PR-1101S #2
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
66'' root grapple (A53421)
66'' root grapple...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
