Satoh s650-g steering slip
   / Satoh s650-g steering slip #1
650joe
Polk, PA.
Satoh 650-G
New member with a steering slip in my older Satoh S650.
Happens occasionally.
Thought the steering system column was pinned and/or splined?
Is it repairable and are the parts available?
Thanks!
   / Satoh s650-g steering slip #2
Just redid my 650 and the column had keyways and square keys in top and bottom!--- its a bear to get in there too! thanks; sonny580
   / Satoh s650-g steering slip #3
Has to be a broken or rounded keyway on the steering shaft. Can't imagine gears inside slipping.
Unless obivious loosness in the pitman arm.
Lee
   / Satoh s650-g steering slip #4
Pitman arm is also a bevel shaft with a square key in it! thanks; sonny580
Sonny,
Find it hard to believe that keyway has failed.
Did you replace any parts ... bearings etc.? If so where did you get them. If I go in I would like to redo everything from the steering column to the spindles.
Thanks,
Joe
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
