Gadgetnut
- Joined
- Oct 27, 2005
- Messages
- 144
- Location
- San Juan Islands, Washington
- Tractor
- Walker Mower MD (Kubota,) BobCat ToolCat 5600 Turbo rev. C, John Deere tractor
I have a thirteen year old Weil-McLain 115,000 btu/hr oil-fired boiler that is used to heat water to provide infloor radiant heating to a medium sized house. Two years ago I eliminated two 80 gallon electric water heaters that provided domestic hot water and installed a 79 gallon indirect water heater in tandem with the above boiler.
When I go away for vacation I turn the entire system off. When I've turned the boiler back on from cold, I've noticed that the hot water recovery time from cold is quite fast-- hot water within the hour.
After the heating season was over, for the three months mid-April to mid-July, I used 160 gallons of heating oil to run the boiler, just for domestic hot water. Two people at home, don't use a great deal of hot water.
I read that indirect water heaters were efficient, but I notice my boiler running many hours a day and the utility room the boiler is in is very warm all the time from the boiler running. There is no infloor heat demand in the summer, so only reason boiler is on is to satisfy the indirect water heater.
I imagine this older boiler is not very efficient and being large enough to heat a whole house, it's overkill for just the hot water heater's needs. At $2 a gallon, I'm spending a little over $100 a month for hot water heating for two people.
(I am familiar with the on demand, point of use hot water heaters... I don't have natural gas, and not a great source of propane either. Don't know if there are electric on demand water heaters or if there's any point to that.)
We only need hot water in the morning for showers, after that warm water is sufficient. I have a timer that can turn on the oil fired boiler for just three hours, 6am to 9am... will this hurt the oil fired boiler to let it cycle from hot to cold and turn it on and off again everyday-- or is this just a boiler cycle which is a boiler cycle and it doesn't matter?
It may not save any heating oil to heat furiously for three hours then nothing for 21 hours, but if this pattern won't harm the boiler I may try it for a couple months and see what the change in consumption is. Thanks for any input.
