ben2go
Yesterday I was cutting 23/32 inch OSB.Both my circular saw (skill saw) and my jig saw (reciprocating) saw kept kicking back.I have a steel ripping blade with hardened teeth on my circular saw.It has 3 to 5 cuts on it prior to yesterdays antics.My jig saw has a new standard fine tooth steel blade for plywood.Both left a ragged cut edge.I expected that with the circular saw blade,but not the jig saw.I couldn't hardly keep the jig saw flat against the wood.I have used these blades to cut OSB before but it was a little thinner.I have my circular saw set to cut 3/16 past the OSB thickness.Should I cut closer to the thickness of the OSB?Also,what's a good blade for cutting OSB?
