Scotts S1624 will not stay running
   / Scotts S1624 will not stay running #1
Meanie
Pataskala, Ohio
Scotts S1642
I have a Scotts (by John Deere) I got from a friend 2 years ago. I tried to get it running last year but then left it alone. I started working on it again today. I replaced the battery today and the solenoid under the carb. Before it wouldn't start at all unless we spayed starting fluid into the carb. After replacing the solenoid and the battery it tries to start but won't stay running. with it on full choke it tries but won't start if we move the lever down to the slowest setting it will start and run for a second or 2 then shut off. Here's the weird part, with the lever in the choke position if I manually move the throttle level back tot eh slow position ( I am talking about the arm on the top of the carb) but keep the butterfly shut, it will start up and stay running. as soon as I let go it shuts off. If I move the lever by the steering wheel at all it will shut off. I'm not sure what the issue is but something is not right. Suggestions?
   / Scotts S1624 will not stay running #2
Fuel to or from the carburetor would be my best guess. You know you have spark, as it runs on what you spray in there.
I'd pull the plug and put a few drops or half teaspoon in the spark plug hole to see if it will run on gas.
Then go into the carb if fuel is making it to the carb ok.
:welcome: to TBN
   / Scotts S1624 will not stay running #3
carburertor is gummed up in side,take apart and clean. might try some sea foam in it
   / Scotts S1624 will not stay running #4
Take the hose off the fuel pump and see if you can pump fuel. Next you might check your gas cap. Mine wasn't venting which caused it to run and quickly die.
Gassers require 3 things, air fuel and spark...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2803 (A50460)
2803 (A50460)
Farmtrac 80 2wd with loader and limb risers (A53473)
Farmtrac 80 2wd...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
7061 (A53421)
7061 (A53421)
