screw anchors on frozen ground
   / screw anchors on frozen ground #1
sparc
Veteran Member
NJ
JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
anyone have a good tip for getting anchors in the frozen ground , beside waiting for spring .
Tried using a pick to get through the first 6 inches, tough going. It's 20 deg here and ground is nice and hard.
we got them in. they are 4 foot screw anchors with two ~5" diameter screws. had to dig with the pick another foot, so about 18 inches down ground was soft enough to get them going. i had 8 of them to do. it hasn't been cold here for long. last week it was in the upper 50s and only dropping into the mid 30s at night, so I didn't expect the ground to be frozen this deep so fast. it just turned cold monday with that cold front that blew in from Michigan/Ohio area, since then it has struggled to get above freezing at mid-day.
Anyway, jobs done so that's that.
   / screw anchors on frozen ground #4
A bit off topic but I needed to access my pump in my septic system as it had failed.
That light bulb (idea) lit up.
I took firewood and built a fire over the concrete lid and had my wife feed the fire while I went to buy a replacement pump.
By the time I returned the ground over and around the lid was nicely thawed and the lid came off just like in summer. Even with a pick I had been unable to make any progress.
Good news was that the float switch had simply got itself tangled in the off position due to a 3 day power failure and was easily rectified.
   / screw anchors on frozen ground #5
Sounds like you got lucky and did not have to do a switch out in the cold.
STOP! IMPORTANT INFORMATION BELOW (A49251)
STOP! IMPORTANT...
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
3pt Wood Chipper (A49251)
3pt Wood Chipper...
500 Gallon Diesel Tank (A47369)
500 Gallon Diesel...
Easy Flo 220 Bushel Gravity Wagon (A49251)
Easy Flo 220...
2010 John Deere 310J 4x4 Loader Backhoe (A46683)
2010 John Deere...
