Sealing Concrete
   / Sealing Concrete #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
I am just about to have a floor poured for my new pole building. I wonder about sealing the concrete. My concrete guy says he can apply sealant when he cuts the expansion joints after the pour and set up. Question: Should I wait longer to seal, or is this ok??
I am anxious to get the building into use...but I plan to stay off the new concrete for about a week....and hate to wait any longer with a sealer. I sure recognize the value of a sealer when it comes to sweeping and cleaning. :)
   / Sealing Concrete #2
It should be sealed as soon as he is done power troweling
   / Sealing Concrete #3
I would agree with above. The sealer acts to "lock" moisture inside the concrete which allows a better/stronger cure IMHO.
As far as a product name I plan to use BASF Sonneborne Kure-n-Seal.
   / Sealing Concrete
Hmmmm.....that seems to trigger my memory....and I think that's what he was telling me. Thanks for the advice.
   / Sealing Concrete #5
Agree with all above - Kure-n-Seal -as soon as the power trowel is off the floor. We used to use an 18" roller working out of a wheelbarrow. If you use a sprayer clean it immediately or it's a one time use. You might ask your finisher to leave it "fuzzy -not burned" so it won't be as slippery when wet. If he's any kind of finisher he'll know what that means. MikeD74T
   / Sealing Concrete #6
I have sealed the concrete on the floors of all my pole barns and garages. The kind I use I get from the local Sherman Williams store. It is applied after the concrete has set up. I then apply a Sherman Williams two part epoxy coating over that. It holds up real good and makes cleanup very easy.
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2020 KUBOTA RTV...
1984 Crown Victoria Sedan (A52377)
1984 Crown...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
