Seat Repair
   / Seat Repair #1
Methodicalsearch
Leesburg
Kubota
I have a 17 year old Kubota B7500 and a 18 year old Cub 2186 that live outside. Both seats have cracks all over about an inch wide and as long a 12 inches. I became frustrated with the "wet bottom" deal so I took some "Great Stuff" insulating foam sealant that I've had for several years and fixed it.
1 - Trim curled up edges until flat.
2 - Insert Great Stuff tube in crack and press along the length of the crack.
3 - Let it dry for a couple hours.
4 - Trim the dried foam with a sharp knife flat with the surface of the seat. You can use a flat rasp for curved areas if you wish.
5 - Using a pair of surgical gloves (disposable) cover filled crack with black Shoe Goo and smooth with your glove covered finger making sure there is over-lap to good seat surface
(a putty knife does not work).
6 - Let it dry over night.
The top of the Kubota seat was significantly deteriorated and required a bit more finesse to rebuild the foam. I used a flat rasp to smooth the Great Stuff before applying the Shoe Goo but it worked.....It is not pretty but so far so good.
Just a thought......Sometimes frustration can be the mother of invention.......Jerry
Toro Reelmaster 5400-D Fairway Reel Mower (A55851)
Toro Reelmaster...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2017 FORD F-150 XLT CREW CAB TRUCK (A52706)
2017 FORD F-150...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
