Oil & Fuel Sediment Bowl.......
   / Sediment Bowl....... #1
VA TO30
Winchester, VA
52' Massey Ferguson TO-30
Hi all,
I am the proud owner of a sweet 52' TO30. I need to replace the sediment bowl since the thumb screw is leaking fuel after multiple attempts to stop the leak. After looking at the position of the sediment bowl and theory behind it, is there any way I could eliminate the sediment bowl completely and install an inline fuel filter instead? Has anyone done this or can anyone offer insight on this matter good or bad? Thanks in advance
Anyone....buller....buller.....please!
   / Sediment Bowl....... #3
I'm not familiar with this bowl but all these are, obviously, is a fuel filter. Having this type allowed for easy in-field service and draining of water. But a modern paper filter would serve the exact same purpose and I wouldn't hesitate to try it. I had an old Farmall that had a paper filter that replaced the bowl.
   / Sediment Bowl....... #4
Hi va to30.
If you remove the complete assembly from the fuel tank and go to the shop that sells fuel filter assemblies ,the one you want is a C.A.V unit with a Sedimentor glass bowl, which has a handy little water drain tap on the bottom of the glass bowl this filter assembly will fit onto the fuel tank with a 90 degree elbow ,brass or stainless steel is best if you feel it needs aditional support make a small bracket .
the C.A.V filters are very cheap to replace i suggest you buy half a dozen spares.
Happy days
Hutch.
2018 FORD EXPEDITION (A51406)
2018 FORD...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
