Seepin Septic
   / Seepin Septic #1
BigEddy
Eastern Ontario
JD 855, 322, AMT626 plus whatever my son dragged home this month
My front lawn is pretty wet these days, snow melt and rain, but I noticed a spot that was bubbling up. Theres a bit of a low spot in the lawn right there, and it seems my weeping tile is only 2" under. With all the water in the ground, it had nowhere to go but up. So I have a small smelly spot.
I thought weeping tiles were typicaly 6" or more under, so I'm a bit surprised to find it that close to the surface.
Given its on the slope of the mound, and a bit low anyway, I'm thinking of dumping another 2-3" of topsoil on top and hoping for the best. Never noticed it before, and certainly wasn't soggy last summer. Any suggestions?
   / Seepin Septic #2
Take your hoe and carefully dig on both sides on the leak and take a look. If the line is not broken, just cover it back up.
   / Seepin Septic #3
Check this site out, I had it done to my leach field 2 years ago and has made a big difference. The inject polystyrene pellets in the ground with 300lbs of air pressure. It opens up drainage channels undreground for better absorption.
TerraLift
Several Ontario dealers that do it, but not sure if any is close to you.
TerraLift in Ontario
   / Seepin Septic #4
How low is the "low spot". I'd opt for a few inches of sand with another inch or 2 of decent topsoil.
   / Seepin Septic #5
Where is the spot in relationship to the line? Beginning, mid-point, end?
I would not dig anywhere near the lines. Depending on how they buried them, rocks gravel, etc. May go all over the place.
See how it behaves when the weather starts drying up? If stays, really wet, and depending on where it is, then yes....
I'd call in someone before I'd try it myself.
A professional opinion cannot hurt.
-Mike Z. /forums/images/graemlins/smirk.gif
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
