sensing rod
   / sensing rod #1
tmar04
YM 276
how do you check the adjustment on ym2500 3 pt hitch sensing rod? my lift doesn't begin to lift til lever almost full up position. doesn't seem right. seems it should begin to lift when lever is first put into up position. thx
   / sensing rod #2
You should have a square block on the rod with a cap screw to lock it in place. Loosening and sliding the block forward or backward directly changes the hand control position. If the block is too far out of adjustment then it's possible to over extend the rock shaft arms and pull the hydraulic plunger out of the assembly.
Mark
   / sensing rod
Thanks, Mark, for response. I adjusted it out some and it mov ed the point of engagement down some. OK now. cheers. Terry
1985 International 1954 Grain Truck (A53117)
1985 International...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Mechanics Truck (A51692)
2019 Dodge Ram...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
