Shear bolts -- possibly older terminology
   / Shear bolts -- possibly older terminology #1
VistanTN
middle TN, closest to Beechgrove, then Bell Buckle
A-C 5020-4, Mahindra 6500 4WD, Kubota L4740 HSTC 4WD
My "new to me" but very old IH Model 46 baler has several shear bolts. The operator's manual (a reprint) talks about type 1 (regular), type 2, and type 3 (special) bolts and says use type 2. The picture shows a bolt head with three hash marks that I would call a grade 5 bolt. Is this correct? I don't want to put in a grade 5 if it is too hard and will cause the machine to be damaged, but the normal cap screw (grade 2) would be a mistake if it is too soft. Figured if anybody anywhere can tell me, you all can.
VistanTN
Time for second cut haying ...
   / Shear bolts -- possibly older terminology #2
a grade 5 bolt will have 3 slash marks and a grade 8 will have 6....that is what I've been taught......the grade 2 and softer bolts do not have any slash marks...
Mike
   / Shear bolts -- possibly older terminology #3
ASTM A449 Specification - Portland Bolt
You might try calling these guys or it seems like they have a chat page.
This link gives some specs you might compare to the grade 2 and 5 on another web page. It seems that the markings on the bolt would indicate gr 5. (three bars) Does ASTM show up anywhere in the book?
   / Shear bolts -- possibly older terminology #4
I have a IH McCormick model 46 also and I have never had any problem with the Tractor Supply Company cheap bolts. I buy them by the pound. I believe they are grade 5. I've run it like that for about 6 years now and over 10000 square bales.
Just go to TSC and tell them you want a low grade bolt that will shear and they'll point you in the right direction.
TSC carries grades 2,5, and 8 with 2 being weakest and cheapest. If you've had no problem with those, that's a safe way to go. I was just confused by what the manual called "type 2" in several places and then the companion illustrations that showed what I was taught was a Grade 5 (add two to the number of hash marks). I guess since most commonly you can only find grades 2, 5, and 8 that could be what they are calling type 1, 2, and 3.
Thanks for the responses.
VistanTN
UNUSED FUTURE FT850J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
