Sheared off cooling fan blades - - Symptoms?
   / Sheared off cooling fan blades - - Symptoms? #1
Tdog
Platinum Member
SE Louisiana
BX22
The talk on TBN about the vulnerability of the transmission cooling fan got me curious about what shape mine might be in. My BX-22 spent the 1st year & a half with the mower deck installed. Removing/reinstalling it was something I thought would be harder than it turned out to be. Whatever, I’ve done quite a bit of clearing – grubbing w/o the mower deck & I’ve been in some pretty serious tree debris.
The bad news is that, sure enough, my little plastic blades are sheared off. I have no idea how long the fan has been in this condition.
I guess my general question is, other than physically looking under the tractor or having a transmission oil temp gage, is there any other way to tell the fan is kaput? What sort of symptoms in performance should have shown up? I checked the hydraulic oil dipstick & the level is OK, & the fluid did not look dark.
I will get the fan replaced [& buy a skidplate!], but I suspect replacing it is more of a job than I want to tackle. Guess that’s gong to be kinda pricy.
Jack
   / Sheared off cooling fan blades - - Symptoms? #2
I've read that the rear universal joint can be disassembled, and that saves a lot of work. I also heard that it can be done by removing only one mower mounting bracket/rod. Since I haven't looked at one closely enough to verify that, I can't give you any assurance that it will work out that way. It sure is worth a look though, and will save a great deal of work/ expense if it does!
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
John Deere Z915E Zero Turn Mower (A51573)
John Deere Z915E...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Electric Concrete Mixer (A51573)
Electric Concrete...
