Shell Rotella ELC Coolant in CK3510 and DK55
   / Shell Rotella ELC Coolant in CK3510 and DK55 #1
kck8385
Kioti CK3510 and DK55
I am going to change the coolant in my 2021 CK3510 and 2008 DK55. They both currently have standard green Ethylene Glycol coolant.
I have purchased Shell Rotella ELC Extend Life coolant 50/50 pre-mix. The data sheet states it is Ethylene Glycol based which is what the manuals say to use. The Shell product is red instead of green but it is still Ethylene Glycol based.
Question: Do I need to do any kind of special flush when changing to the Shell coolant or just drain it, flush it with tap water and fill it up with the Shell?
Thanks,
Kevin
   / Shell Rotella ELC Coolant in CK3510 and DK55 #2
It is best to flush with water prior to changing coolant chemistries. No special flushing products required, but I personally do a final flush with distilled water.
FYI, the majority of coolants are ethylene glycol BASED, with many different chemistries.
   / Shell Rotella ELC Coolant in CK3510 and DK55 #3
Kubota has always and still do use conventional green coolant so I do as well and I drain and flush my cooling systems every 2 years anyway.
I know of a guy down the road that went from conventional green coolant to red extended life and didn't flush his cooling system and the mixing of the green conventional coolant with the extended life turned the coolant to goo...
I appreciate both of your replies. I misunderstood what ethylene glycol based meant. Glad I didn’t screw something up. I’ll just buy some green and keep it simple.
Thanks again,
Kevin
2018 Chevrolet Traverse LS SUV (A44572)
2018 Chevrolet...
2016 Ram 2500 Pickup Truck, VIN # 3C6UR5CL0GG391142 (A44391)
2016 Ram 2500...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2008 John Deere 9570 STS Combine  Front Duals  Premium Cab  1,704 Sep Hours  Clean & Field-Ready (A46877)
2008 John Deere...
Earthway Seeder (A44391)
Earthway Seeder...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A45046)
2011 MAGNUM...
