somanytractors
I finally got to dig into this thing a bit.
I pulled the hose off the pump and nothing came out even though the tank was half full.
The strainer was completely clogged.
After cleaning the strainer and filling it with fresh fluid it seems to work pretty good.
The diverter seems to be loosening up but its still pretty stiff. I'm hoping it will loosen up. If not I'm sure I can get it working.
I was surprised that only one cylinder leaks. I was expecting at least a few of them to leak.
And none of the valves leak.
It's actually in better shape then I thought.
Although I think there may be an issue with the leaking cylinder beyond the leak. It's one of the cylinders that swing the boom from side to side. Besides the leak the boom seems to sway way too easy. You can actually push it by hand. But the leak is really bad so I'm hoping its just air in the cylinder. I guess I'll see once I get the seal replaced.
