Shibaura 2803 hyd lift fluid change
   / Shibaura 2803 hyd lift fluid change #1
jjames23
Need help on changing the hydraulic fluid in the Shibaura 2803. Here are my questions.
1. Is there a hydarulic filter?
2. Is there a dip stick to check the fluid level?
3. Where is the location of the fluid drain plug(s)?
4. What is the location of the fill port?
I have a corresponding ford operator's manual but it is not very clear to me about the above information. I would rather be sure than make a big mistake.
I do see a dip stick on the floor area between the operators leg but am not sure what fluid it is (smells like engine oil). There is also what appears to be a fill plug in the rear of the tractor behind the operator's seat. Your help os greatly appreciated.
Jesse
   / Shibaura 2803 hyd lift fluid change #2
1. Yes, usually located on top of the pump or just in front. It is a cleanable screen
2. In front of the shift levers below the steering wheel
3. Bottom side of the transmission
4. behind operator’s seat
The transmission is the hydraulic reservoir. Replace with "universal tractor fluid" JD303 or equivalent.
Buck
Thank you so much!!! I'll be on that task this coming weekend.
2018 KENWORTH T370 REAR LOAD GARBAGE TRUCK (A52576)
2018 KENWORTH T370...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
