Shibaura SP1540 Hydraulics Stuck Up
   / Shibaura SP1540 Hydraulics Stuck Up #1
franklyspeaking
My hydraulics are stuck in the up position with the bush hog attached - most of the tractor weight is on the front wheels and bush hog wheel. I see a slight movement down when I actuate the joystick down, and then nothing. The up direction then moves slightly up and then strains (full up). I checked the downside of the control valve, and I get 12 volts when the actuator is down. Appling 12 volts to the down side yields nothing. The manuel over-ride switch also does not work. The up over-ride makes the system strain - seems okay.
Is my spool valve toast or am I missing something? It does seem that there could be something preventing it from going down, but I can't see anything? /forums/images/graemlins/confused.gif
Is there anything I can do to get the hydraulics to let the tractor down?
   / Shibaura SP1540 Hydraulics Stuck Up #2
Call me 509-374-3398 ext 2. I can help
Buck
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Generac SD36/87810 (A47384)
Generac SD36/87810...
New Calf Hut (A50515)
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
