Shifting Glitches, M4700
   / Shifting Glitches, M4700 #1
dentonsisk
Lyncyburg, Virginia
Kubota M4700, Ford 8N(2), Farmall Cub(2)
Have an M4700 with mechanical shuttle shift. I do really like the shuttle shift transmission's layout and convenience. I am having a little trouble however. When shifting foreward from Reverse to Low the transmission is very smooth. When shifting from Neutral to Reverse or Neutral to High it is very smooth. When shifting from Low to Nutral it sticks very badly. Engine RPM and oil temp do not seem to affect this behavior. If I pull the Shuttle Lever towards the seat (to the right) while in first and then pull back to Neutral it does seem to shift a bit easier.
Might anyone have a guess at the cause?
Thanks in advance for any responses.
Denton
Lynchburg, VA
Specs
M4700
Shuttle Shift (mechanical)
450 Hours
LA1001 FEL
After much investigation I finally figured out the culprit for the shifting problems. It was the start interlock detent switch. I put a little axle grease on it and it shifts like new.
denton
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
Super Material Lift MH1000 (A52748)
Super Material...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
378801 (A51572)
378801 (A51572)
