Mowing Shredder studders when PTO engages
   / Shredder studders when PTO engages #1
Manueleg
harker heights, TX
kubota
Question - Just got a Kubota L4600 with a hydro static transmission, I was under the impression that you do not have to depress the clutch when engaging the PTO to run the shredder, but when I engage the shredder on the PTO there is a severe jolt. I have the RPM below 1000 when I engage the PTO but haven't depressed the tractor clutch. Am I doing something wrong? Should I depress the tractor clutch? is the jolt normal? 2) what should I do to reduce the jolt?
   / Shredder studders when PTO engages #2
That is normal, the blades are mounted on pins or bolts and swing freely. Until centrifugal force straightens the blades out they are out of balance.
   / Shredder studders when PTO engages #3
If you have a clutch and it can be used to gently engage the PTO, I'd use it every time.
   / Shredder studders when PTO engages #4
Manual clutch - let it out slowly, you will still get a little shudder.
Electric clutch - it's going to shudder as when the hub starts to spin it can actually get the blades spinning around the pivot pin for a bit until the centrifugal force holds them out- takes a second or so sometimes. Nature of the beast.
   / Shredder studders when PTO engages #5
Pretty much the nature of cutters, on the Kubota, at least on mine, you can use the clutch, to get a bit smoother spool up, but I don't bother, all our tractors with independent PTO do the same thing when engaged, just engage at relatively low RPM and you will be fine.
   / Shredder studders when PTO engages #6
I have the L3130 and unless the L4600 is different, or I miss read the issue there should be a lever that engages the PTO.
If you push the lever into the engage position in one swift movement you will get the "jolt". You need to feather or slowly move the lever to the engage position at a low RPM. This should greatly reduce the jolt of the PTO engaging.
David
thanks, guys. Really appreciate the quick response.
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
