Size of battery cable?
   / Size of battery cable? #1
rooftrussman
Northern Virginia
Ford 1210 (1986)
I have a Ford 1210 that has assorted starting problems but am narrowing it down after shorts, bad alternator, old battery, key switch etc. but seems that the last weak link is the battery cables. The ground is a 4 ga that is easy to find. The positive looks to be an old 1 ga about 42" long. Tractor Supply advertises one available in store only but Tractor Supply is a long ways a way. The Ford1210 is a 16hp diesel. Would a 2ga or2/0 ga cable work as well. Not sure the one on the tractor is original. I could try the Ford dealer but am cheap for this sort of thing.
   / Size of battery cable? #2
Use 2 gauge at a minimum for both cables. If the ground cable still is bolted to the battery tray, run it to a better spot on the chassis or engine block. 1/0 will work better for longer than #2, but 2/0 is probably overkill for that battery and starter.
   / Size of battery cable? #3
I'll add to clean up the ground location wherever you attach it.. get down to good metal.. then grease the conenction.
soundguy
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
