Size of finish mower for my L3400?
   / Size of finish mower for my L3400? #1
tomfifield
Eagle creek Or
Kubota 3400
Kubota L3400 has 29 PTO HP. I run a 60" Bush Hog just fine. Would a 72" finish mower be to big or should I get a 60"?
I am thinking a rear discharge mower would be best, what do you think?
   / Size of finish mower for my L3400? #2
I'd go with a 72" RFM. You've got plenty of PTO HP for it. If fact, you can handle an 84" RFM...
Now, there are caveats:
1) If your lawn is uneven (lots of dips and rises), a larger RFM can span the dips and scalp the rises..that makes for an uneven looking cut.
2) If you have areas that are narrow, a larger RFM may not work for you.
3) If you park your RFM in a garage or building, make sure the door is wide enough!
I had an 84" RFM that came with the 30 PTO HP Deere 4400 I own. I had problems 1) and 3).
I ended up selling the big RFM and going with a 72" model which works much better for me.
   / Size of finish mower for my L3400? #3
What Roy said, we run a 7' Caroni on a Ford NAA.
   / Size of finish mower for my L3400? #4
You can run an 84" .
I run an 84" with 28.3 PTO HP, no problem at all.
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
