Size pump needed to run pto speed on a 18 gpm system
   / Size pump needed to run pto speed on a 18 gpm system #1
Rio_Grande
Platinum Member
Am contemplating a 3 point hook up for my skid steer with a method of operating a pto at 540 rpm. What size displacement motor would I need for that?
My other alternative is building a direct drive hydro driven auger for post holes. What is the displacement needed for that.
   / Size pump needed to run pto speed on a 18 gpm system #2
What kind of motor cubic inch wise do I need for a direct drive auger?
   / Size pump needed to run pto speed on a 18 gpm system #4
Using 18 GPM, a 28 cu in motor will turn up to 149.
Torque is fairly constant through the rpm range.
Do you have remotes?
If you have about 2500 psi, your torque will be about 11,146 in bs.
Yes I have remote connectors. The gpm is at 3000 psi if I remember correctly but I don't intend to sit there and run it wide open to auger post holes. If 28 in2 will work I can find one somewhere.
Thanks JJ
   / Size pump needed to run pto speed on a 18 gpm system #8
A formula from school a while ago, that I still remember may be helpful.
HP (input)=GPMxPSI / 1714
Let me know if that helps.
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
