Sizing PTO tiller for tractor
   / Sizing PTO tiller for tractor #1
MNBobcat
Platinum Member
Hi Guys,
I have a JD 3020 diesel which is about a 70hp tractor. First tractor and while I'm trying to learn I don't know much about implements.
Tractor Supply has a 60" PTO tiller that says its rated for:
Hitch Category : 1
Power Rating : 25-40 HP
If I put one of these behind a 70hp tractor am I running the risk of tearing up the tiller? I wasn't sure if the power rating was to make sure you have enough tractor to run it or if its because a too powerful tractor might destroy it and if I would need to buy a heavier duty tiller?
Thanks!
   / Sizing PTO tiller for tractor #2
I owned a 3020 for the farm for many years. They are good tractors. If the tire track width was set like mine, you need a 84" to cut out your tracks. Otherwise you are just going to be compacting soil with that much weight and a 5 ft tiller. Ken Sweet
   / Sizing PTO tiller for tractor #3
If you can afford it, I'd go w/ what Ken said....get one that will cover your tracks. Specs show that model @ 89" wide....you'll need at least the 84" wide tiller. I don't think you'll like the 60"unit??
As for too much HP, you don't have to use all your RPMs to use the tiller. Just looked up your model on Tractordata.com and the rated PTO HP is b/w 59hp & 66hp b/w the gas, diesel, & LP engines. I would just throttle back and enjoy!! Good luck:D
   / Sizing PTO tiller for tractor #4
The hp changed throughout the years, starting at 55 PTO hp with the 3010 moving up to 70 PTO hp with the last years of the 3020. Regardless even at idle a 3020 would tear up any tiller TSC sells.
As stated before, I would be looking for something in the 7-8' range. Most tillers when you get that big will be made for larger tractors and can handle that amount of power. Muratori and Sitrex both make tillers this size, probably some other brands out there as well, but those are the two that come to mind.
   / Sizing PTO tiller for tractor #5
Once you go past 72 inches, tillers get pretty pricey pretty fast. I do have the Phoenix and First Choice bigger tillers. Your cheapest way out would be to get a 3 bottom plow and a disc for the 3020. Ken Sweet
   / Sizing PTO tiller for tractor #6
For a 3020 diesel I would consider the Frontier RT1280 or RT1380 models. There are other makes and models that would be good too but the ones I mentioned would be an example of an appropriate size.
   / Sizing PTO tiller for tractor #7
Hi Guys,
Hitch Category : 1
Thanks!
Is,n't your tractor a Category 2 ?
The gear box on the tiller is way to light for the hp of the tractor, but it would work. If you get it I would make sure the slip clutch is setup for the hp of the gear box & not the hp of the tractor. If you can afford it I'd get a heavy duty tiller that would match your tractors hp. Less chance of damaging the gear box and pto shaft if something got jammed in the tines.
To answer the question about the tiller power rating: 25 is the minimum and 40 is the maximum pto hp recommended by the manufacturer needed to run the tiller.
   / Sizing PTO tiller for tractor #8
you might get away with a smaller size tiller. but make sure you can off set everything, so the tiller covers at least one tire track. what i mean by off set, is that you are able to move the brackets on the tiller to one side. so the tines on the tiller itself are no longer centered behind tractor but cover one tire tract.
HP ratings. as what others said, get a PTO slip clutch (fits between the tractor and shaft that goes to the tiller.) that is rated for max or less HP of what the tiller is rated for, vs in your case your tractor HP.
pretty big tractor for a tiller though. i can understand just wanting to say till up a smaller garden. but you might find a Plow, disc, harrow. be better for bigger areas.
hit Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements. and/or YouTube - Broadcast Yourself. and do searchs for videos. (assuming you have high speed internet)
and keep asking quesitons here on TBN.
   / Sizing PTO tiller for tractor #9
I've been using a 72" King Kutter on my M7040. I must say, its a pretty tough tiller.
Thanks guys, that helps. I've heard mention of category 1, category 2, etc but being new to tractors didn't know what it meant. I did some searching and found this, "The John Deere 3020 tractor has a category 2 three point hitch and its pto tested at 71 hp".
I also found an explanation of what those categories mean. So it sounds like I'll need to find a category 2 tiller and will need to measure my wheel base with the wheels set at their narrowest. I've been wanting to narrow up the wheels anyway because its easier getting in and out of the woods when I'm cutting firewood.
I have a 15 foot batwing mower and I'm finish mowing about 10 acres which I fly off of. I needed the HP to run that big mower.
I decided on going with a tiller because I could do what I need with just one implement versus plowing, discing, etc. I guess it may come down to total cost of investment. 3 to 4 bottom plows seem to start at about $500 for anything used that's decent. We are all sand here. Soil should be easy to work. I'm planning on bringing in a bunch of horse manure (easy to get and free) and tilling it in and adding lime and fertilizer. This is for 2 - 3 acres where I'll be putting in a garden and planting fruit trees.
2008 Ford F-150 Pickup Truck, VIN # 1FTPW04598KC49674 (A44391)
2008 Ford F-150...
2019 VANGUARD 53FT DRY VAN TRAILER (A43004)
2019 VANGUARD 53FT...
2006 INTERNATIONAL 9200i SLEEPER (A43004)
2006 INTERNATIONAL...
John Deere PowerTech 8.1L Power Unit (A44502)
John Deere...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2017 INTERNATIONAL...
33ft Box Trailer (A44391)
33ft Box Trailer...
