Skid Shoes for Woods blade
   / Skid Shoes for Woods blade #1
FABEATS
Novelty, Ohio
Kubota B7500, ZG23
I just got a price from my local dealer on a pair of skid shoes for my RB72 rear blade. He quoted me $144. Does this sound right? I was kind of shocked. Anyone know of a cheaper price for these or has anyone made a set yet. I would appreciate any advice. Thanks in advance.
Joe M.
   / Skid Shoes for Woods blade #2
FABEATS,
I'm hip baby!!! They cost about what --- 25% of the blade?
What's up with that. If you do find a source please let me know.
Thanks,
Nick
   / Skid Shoes for Woods blade #3
I was told by a dealer in my area around $130.
Solo
   / Skid Shoes for Woods blade #4
looks like you should try and cut a deal for the shoes when buying a blade. What about those highly polished First Choice blades. Do they have a shoe option? bw
   / Skid Shoes for Woods blade #5
I WAS LOOKING AT MAKING SOME. I WAS THINKING ABOUT TAKING SQUARE TUBING OF 2 DIFFERENT SIZES SO THAT ONE WOULD FIT IN THE OTHER WITH SOME EASE AND SLIDE IN AND OUT. TAKE SOME ROUND PIPE AND WELD TO EACH SIDE OF THE BLADE AND TAKE ANOTHER PIECE THAT WILL FIT ON THE INSIDE OR OUTSIDE OF IT AND WELD IT TO THE LARGER SIZE SQUARE TUBING. SLIDE THE ROUND PIPE WELDED TO THE SQUARE AND SLIDE IT OVER THE ONE WELDED TO THE BLADE AND DRILL ONE VERTICAL HOLE THROUGH BOTH PIECES SO THAT A PIN WOULD FIT THROUGH AND LOCK THE SQUARE TUBING IN THE UP OR DOWN POSITION. NOW DRILL HOLES THROUGH BOTH PIECES OF SQUARE TUBING IN WHAT EVER INCREMENTS YOU WANT SO THAT YOU CAN LOCK IT IN PLACE A WHAT EVER DEPTH YOU REQUIRE. NOW TAKE THE SQUARE TUBING THAT WILL SLIDE IN AND OUT AND WELD A 3-5'' PIECE OF PLATE ON THE BOTTOM WITH THE FRONT AND BACK EDGES ROLLED UPWARD SO THEY WILL SLIDE ACROSS THE GROUND WITH SOME EASE. I PLAN ON PUTTING THIS TOGETHER AND MOUNTING ON MY BLADE TO GET A CONSTANT DEPTH OF MATERIAL ON MY ROAD I'M BUILDING TO MY BARN. STILL TRYING TO FIGURE IT OUT WITHOUT HAVING TO WELD.
   / Skid Shoes for Woods blade #6
I went ot my local snowplow parts dealer and
got a pair of skids for western plow (looked like these
would work best) $25.00/pr.
They are 1" dia. solid rod w/ about 5" dia rounded shoe
the shoe is about 3/4" thick and have stack of washers
to adjust height.
They work in any direction.
I welded 2X4X1/4" (overkill) tube 3" long to back side of blade
after drilling 1" hole in each pc.
Heavy angle will work too .
It can be bolted on also.
I also use these as hitches to pull 2 48" lawn rollers behind tractor
in spring has about 2' gap but works w/ overlap.
   / Skid Shoes for Woods blade #7
Just got new Northern hyd. catalog #972
Page 17 has the western and meyers skid shoes like I put on
my blade (previous post).
A picture might help.
Western is part # 10374-B972 if u want to search website.
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A52472)
2022 ALLIANCE...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
