Skid Steer to 3pt adapter options
   / Skid Steer to 3pt adapter options #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
What other manufacturers make a Skid Steer to 3pt adapter besides Switch-Hitch from Kasco? Based on Spencer's thread, the Switch-Hitch from Kasco is a $500 item, so I sure wouldn't mind shopping around a bit.
   / Skid Steer to 3pt adapter options #2
Mosey, I don't think I have ever heard you mention that you can weld but I will throw this idea out there anyway. TSC (and many others) sell a "quick hitch" that you hook up to your 3-point (I have attached a picture). TSC sells their cat 1 quick hitch for under $200. You can buy a blank skid steer type quick-attach plate for under $80 from a Bobcat dealer. These two items could probably be welded together and then you would basically have a Switch-Hitch. Even if you can't weld I am sure you could take these items to a local shop or even a nearby farmer friend and have it welded up quite reasonably. Now for even a cheaper solution try to find a used quick hitch and instead of buying a blank Bobcat plate just weld the flanges you need directly onto the used quick hitch.
I did a web search and found out that Bradco also makes one. I still need to find a dealer and get a price on one. Here’s their web site:
ATI Products/Bradco
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
