skidsteer or compact tractor
   / skidsteer or compact tractor #1
chinawall
Can anyone tell me the pros and cons of using a skidsteer to till, blow snow, and bushhog instead of a compact tractor such as a Kubota 7800?
   / skidsteer or compact tractor #2
I can't think of any pros; cons would be soil compaction, tearing up the sod/ground cover with the skid steering, and expensive implements.
   / skidsteer or compact tractor #3
Biggest advantage for SS would be visibility. All attachments are in front of operator. Higher flow rate for hydraulics - if needed. Can turn in tighter area and more maneuverable.
   / skidsteer or compact tractor #4
Come to think of it, my brother has a form of HD brush cutter on his Bobcat he uses to clear in the woods. He says it's a beast, really does the job.
WHAT DOES BOBCAT 170 COST..BALLPARK?
   / skidsteer or compact tractor #7
you would be looking north of $22K depending on options you could get over 30k on the new side
   / skidsteer or compact tractor #8
Chinawall,depending on your application you could get into a 30 to 40hp. tractor with all the attachments you want for less than a new bobcat s175.I have always found a tractor more comfortable to use and the attachments are far less in price.You can always find deals on used 3pt. attachments.I sell bobcat and kioti tractors.Just my 2 cents.
my Kubota b7800 won't go near a thornbush without losing the calcium in the tires. That why I thought about a skidsteer
   / skidsteer or compact tractor #10
It's a great deal if you can afford both but if you can only choose one, I'd have a tractor. If for no other reason than every time we use a skidsteer around here when we're done I have to put the blade on the back of the tractor and straighten out the area the skidsteer tore up...
   / skidsteer or compact tractor #11
Chinawall,There are a couple company's that can foam fill your tires so you will never get a flat again.It's not cheap but if you already have the tractor this would save you alot of $.
Hey Kioti, where are these companies?
   / skidsteer or compact tractor #13
Call your local tire companies. If they don't do it, they should know who does, in your area. Equipment rental and tractor shops will know too.
   / skidsteer or compact tractor #14
What about a ToolCat to replace the skid steer AND the tractor. One set of implements, more expensive than a compact tractor, but cheaper than a skid steer.
DEWFPO
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2436 (A60432)
2436 (A60432)
