Slab vs Helical Pier vs Concrete Pier
   / Slab vs Helical Pier vs Concrete Pier #1
ocaj11
Northeast Texas
John Deere 5325 4wd, Kubota B7500 HST
I would like to get some opinions on this topic. We are getting ready to build a house on expansive clay soil and I'm trying to figure out which foundation to use. I've read lots of opinions on the Internet, but still can't figure out the most cost effective way to proceed.
I would like to build approximately 2000 sf in a single story, but, I would consider a 1.5 or 2 story if that was less expensive. My plans are to pay someone to do the dry in and I'll do most of the rest as time allows. I'm not in a big hurry once the house is in the dry. I'm located in Southwest Arkansas around Texarkana and I believe the neighbors (1/3 mile) soil test came back with a plasticity around 45 (not 100% on that). A few of the questions I have:
1. We talked to a helical pier installer and he said they usually go around 6 foot deep here to get the required torque. They seem to rely on the torque value to define satisfactory depth. I'm sure the seasonal moisture variation is deeper than 6 feet. What keeps the pier from moving when the soil expands/contracts with more/less moisture? The installer quoted (ballpark) $165/pier at a 6 foot depth. That's $8,250 for 50 helical piers.
2. Drilled concrete piers are an option, but I think you need to go around 15-18 foot deep to keep the expanding/contracting soil from lifting the pier. There is a guy that drills the holes for $100/hr and I have no idea how many 15 foot holes he can drill in an hour.
3. For a concrete slab foundation, I'm not comfortable hauling in a couple of feet of foundation sand and building on top of that. I'm pretty sure we would need to use some sort of pier to support the foundation during the expand/contract cycles. If I'm going to need piers anyway, wouldn't it be cheaper to go pier and beam? We have a 12 yard dump truck and dozer-trackhoe-backhoe to dig out a few feet and backfill with the proper material, but that seems like a lot of work to me and I'm not sure it would be effective.
4. We built a 40 x 60 concrete pad for our metal shop 3 years ago. We weren't too concerned with the slab for the shop, but we did hire the so-called best concrete guy around to do the work. He poured a 4" slab using 12" footings and rebar on 18" (I think) centers. He installed the vapor barrier as well. Eventhough we have a water drainage issue (haven't had a chance to correct this yet) on the back side of the shop, we've only experienced a crack approximately 1/16" wide and 20 foot long. There isn't any seperation to speak of.
5. If we get the slab on proper material and utilize a proper slope to get the water away from the house, is it possible to avoid a busted slab by digging deeper footings, reinforcing the footings with extra rebar and running the interior rebar on 12" centers? 5" slabs significantly better than 4" slabs? Could we pour on 4" of compacted gravel with a drain under the footings to wick any water away?
Basically, there are too many options to choose from and I'm trying to build a proper foundation without killing my budget.
Opinions???
   / Slab vs Helical Pier vs Concrete Pier #2
The Front Range of Colorado is loaded with expansive Bentonite soils. Get a good registered P.E. (Professional Engineer) structural engineer to design your foundation.
A skilled engineer will pick the best combination of pier and foundation type based on your soils report.
This is one are you do not want to skimp on.
Thanks for the reply mjncad.
I know the P.E. route might be the best route, but, from my past experience with them, they tend to over engineer things to make sure they cover any liability they may have. Over engineering is certainly not a bad choice for a house foundation, but it comes at a hefty cost.
My grandmother's house was built on Bois d' Arc blocks sitting on top of the ground. It was built around 1915 and is still standing today. Of course, the floors are crooked and the blocks had to be replaced in the 70's, but the house is still there.
I'm trying to find that point that's slightly better than good enough. There's probably too much guess work involved to do that without professional assistance. :)
   / Slab vs Helical Pier vs Concrete Pier #4
If you want to skimp on the project, the foundation isn't the place to do it. Most other parts of a structure can be easily upgraded at a later date, but that's difficult to do with a foundation.
Any soil with a plasticity index over 25 is considered expansive. Soil with a PI of 40 has the potential for significant movement. Many of the larger home builders use ribbed post-tensioned slabs on ground - I have been told they are the most economical foundation for homes on expansive soils. The design of the foundation will be dependent on many factors, from potential vertical rise of the soil, vegetation around the foundation, the size and shape of the structure' etc. A professional engineer will be able to evaluate all of these factors and design a foundation that will fit your needs and soil conditions.
Do a web search for the 'foundation performance association'. The have a lot of information available regarding foundations on expansive soils.
   / Slab vs Helical Pier vs Concrete Pier #5
Jsheds,
Thanks for that information. I'll certainly look for the 'foundation performance association' and read what they have to say. I've done a lot of research on this subject and I don't think I've been to that site yet.
Have a great day!!
   / Slab vs Helical Pier vs Concrete Pier #7
Lots of Colorado home builders have gone bust while making the lawyers rich because they didn't spend the bucks to engineer a proper foundation for expansive soils.
I'd rather have Formica counter tops instead of Granite or Corian; or mid grade cabinets instead of custom cabinets, etc in exchange for a properly engineered foundation.
Best of luck on your project regardless of how you decide to engineer the foundation.
I'm all too familiar with poorly built foundations. It's going to be my main concern and I plan to make sure it's done properly.
What I would like to do is figure out what over-engineered is and take the money I would spend on soil tests and P.E. foundation designs and put that money into the foundation. Right now, I'm leaning toward heilical piers approximately 10 foot deep into stable soil and deeper than the seasonal moisture variation. I'll bolt the subfloor to those helical piers.
Before I make the final decision, I'm going to read the information from the foundation performance association.
This site is a great resource and I appreciate all the replies....
   / Slab vs Helical Pier vs Concrete Pier #9
Not at all familiar with Texas soils( up here we like basements) but I have always been told by concrete people that a 4" thick slab is suitable for a sidewalk only. Anything structural such as a basement, garage floor or floating slab should be 6" minimum up here if you don't want it to crack.
   / Slab vs Helical Pier vs Concrete Pier #10
If only the slabs were a true 4" and 6" thick. Out here the guys forming 4" slabs love to use 2x4's and 2x6's for the 6" slabs. Which means you are getting a 3-1/2" and 5-1/2" slab respectively.
   / Slab vs Helical Pier vs Concrete Pier #11
I believe there's seven different kinds of clay here in north Texas. Most of us have them in layers. The latest technique I've seen used in better homes and businesses with slabs is removing the soil down a couple of layers, ten or so feet deep. The soil is mixed so that there are no longer layers but a consistant mix of the layers. Then the soil is compacted as it goes back into the cavity. The piers are still drilled and they are still belled.
Some friends of mine in the foundation repair business believe in poured concrete piers. They also agree the two best designs for the concrete piers is the properly belled pier and the repair pier that has two piers from the same haunch drilled like an inverted V. The desgn of these piers precludes not only sinking but heaving.
If I was to build a home in north Texas clays I'd go with pier and beam. The piers would be belled and the beams would be substantial. I just helped a friend build a pier and beam foundation. We didn't bell the piers but his soil is sandy loam with just a little clay.
So far, I haven't been able to find anyone that has the capability to drill belled piers. I also think that would be a good way to go. I'll keep looking to find someone that can give me an estimate.
The helical piers would stop the up/down movement, but I'm not sure how well they would hold up to the sideways movements.
If anyone has a pier and beam that has the girders attached directly to the helical piers, I would like to hear your opinions. Also, if anyone knows a contractor in the Northeast Texas/Southwest Arkansas area that can drill belled piers, I would like to have their information.
Thanks for the replies!!!
   / Slab vs Helical Pier vs Concrete Pier #13
All the pier drilling companies have the capability for belling their piers. Most of them I've seen in action work with two rigs, one drilling the pier and the second belling the hole afterwards.
The way a bell tool works is down pressure forces out wings. The wings feed the waste into the cavity that is the bell tool. The bell tool fills up and is pulled to the surface to be emptied. The process is repeated until the bell tool comes up empty.
A good source for information is the boys in Farmersville Texas at Wylie Drilling. They have some pretty awesome equipment and a ton of experience.
(and they have a cool gate, real nice gate)
John Deere 1025R (A53317)
John Deere 1025R...
(10) UNUSED 2.5" RATCHET STRAPS (A60430)
(10) UNUSED 2.5"...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
2010 CATERPILLAR 303.5C CR EXCAVATOR (A60429)
2010 CATERPILLAR...
1761 (A58375)
1761 (A58375)
