Slip clutch on PTO
   / Slip clutch on PTO #1
CFHartman
Keyser WV
John Deer 2210
Is there a good reason the slip clutch is put on the attachment end of the PTO shaft instead of the tractor end.
   / Slip clutch on PTO #2
I don't know anything about the engineering aspects, but there may be safety issues. I don't think the PTO guard on my tractor (NH TN55) could accommodate a slip clutch.
Steve
   / Slip clutch on PTO #3
I think space is at a premium on many tractors and therefore the slip clutch at the implement end of business. BUT.....I gotta wonder if you were to disintegrate a slip-clutch or even lose a bolt or part from the clutch....it could hit the operator if mounted on the tractor side. (?) :confused:
   / Slip clutch on PTO #4
Much less likely to stick the wrong piece of flesh around the limited slip PTO clutch as it is unshielded and usually partially obstructed by the three point hitch mount on the implement.
Reminds me of the very young son of a former co-worker that caught his coat on a shaft that was not shielded on a sliage wagon and he was killed almost instantly.
OK thanks for all the very good reply's. I guess I wasn't thinking safety at all. I think I will leave it as is.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2009 Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
2009 Grady-White...
